Problem in ASA 5510
manivelengg
Level 2
Level 2
ASA 5510
When I upgrade an  IOS ,  I made  mistake and deleted  flash(disk 0) .... after that I tried to put IOS via ROmmon mode from tftp server and get up IOS an  disk0: . "Everything" is OK ,
Once given the command "reboot" and everything is going off
Which means we cant able to login.
Some error message is follow.
Please help.
Manivel
Julio Carvajal
Hello Mani,
Can you be a little more specific,
Are you saying your problem is that you copy the image from the TFTP to your ASA, then you rebot it and you get a log with an issue?
Is that correct?
Can we see the log mesage?
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
