Problem to Configure Cisco ASA 5505 DMZ
David Aguirre
I'm configuring a Cisco ASA 5505, I configured the INSIDE and OUTSIDE, when configuring the DMZ shows me the following error:
"This Licence does not allow configuring more than 2 interface with name if and without a" no forwaded "command on this interface or on one interface. Whit nameif alredy configured".
Then I followed this guide to achieve: "https://supportforums.cisco.com/docs/DOC-22736", but when trying to connect the new interface shows me the following message: "image has a version number unkonow Which is not supported by ASDM 6.4 (5) "and stays at 11% loading.
thank you very much for helping to get set the DMZ. and solve the problems I have.
There shouldnt be much to it.
First of all you need to do the following
  • Open ASDM and log in
  • Go to the "Configuration" window
  • Make sure that on the lower left hand side you are now on the "Device Setup" menu
  • Choose the "interfaces" section
  • Press the "Add" button on the right hand side of the ASDM window to add a new interface
  • IF you have some previous 3rd Interface on the ASA, remove it first by selecting the interface and then using the "Delete" button
Now when you click "Add" button you should see this window
  • Choose the interface from the left side that you want to attach to the new Vlan you are creating
    • Use the "Add" button to add the interface. Press OK if prompted
  • Configure the interface name in the section "Interface name"
  • Configure the security-level of the interface in the "Security Level" section
  • Configure the IP address and network mask of the new Vlan interface in the field below
  • Next click on the "Advanced" tab in the upper portion of the window
Next you can do a couple of more settings before applying them all to the ASA
  • Choose the Vlan ID you want to use
  • Configure the Vlan interface to which you want to limit the connections from the created Vlan interface
    • In my example case below I chose to limit connections to my Vlan1 / LAN interface
Next press "OK" and in the main window press "Apply" to apply the configurations to the ASA
In my case the CLI format configuration inserted was:
      interface Ethernet0/3
        switchport access vlan 30
      no interface vlan20
      Interface vlan30
        no shutdown
        no forward interface vlan1
        nameif DMZ
        security-level 50
        ip address  10.10.234.1 255.255.255.0
Hopefully the above was helpfull
- Jouni
Jouni Forss
It would seem you have an ASA5505 with a Base License. You can confirm this with the "show version" command on the CLI
You CAN configure 3 Vlan interfaces on the ASA but as the error message says, BEFORE configuring the "nameif" for the DMZ interface you will first need to configure a "no forward interface Vlanx"
This basically means that without a better License you will have to limit the DMZs traffic towards 1 of the other interfaces. Typically this would be done towards your LAN interface
Configuring this restriction will mean that DMZ cant initiate connections to INSIDE. At the same time this WONT prevent INSIDE from connecting to the DMZ though.
So what you would need to do is the following
  • Have the "INSIDE" and "OUTSIDE" configured.
  • Decide to which of the above interface the "DMZ" shouldnt be able to initiate connections to. (Usual being INSIDE)
  • Under the DMZ "interface Vlanx" configurations configure the "no forward interface Vlanx"
    • Where "Vlanx" is the Vlan interface and number of the interface to which you want to limit connections to
  • After the above has been configured, you can then configure the "nameif" under the DMZ interface
Hopefully the above will sort your situation. Please rate if the information was helpfull. If it answered your question, please mark the question as answered
I can't be sure what the problem with ASDM would be. I don't normally use it for configurations.
- Jouni
Thank you very much for the reply;
As could make your solution through ASDM?
      no interface vlan20
      Interface vlan30
        no shutdown
        nameif DMZ
        security-level 50
- Jouni
thank you very much.
Everything worked perfectly and I was able to configure the DMZ, the last thing I want is to change the direction of the INSIDE default (192.168.1.1) on the other direction due to the same address the ISP Router has tried it and will not let me .
I appreciate all your help and excellent service.
