Problem with BGP
murali_k_meda
Community Member
Plz help on BGP, I am working for the ISP. I have Many Backbones, and few Block of Class C ( 195.X.X.X )IPs. Here i am advetising the each block to separate backbones throu rote-maps In BGP How can we split the one Block. For Ex: 195.X.X.0 255.255.255.240 has to come throu one Backbone and Remaining has to come with some other backbone. How this can be achive.
Murali Krishna
mheusinger
Level 11
Level 11
you could advertise a partial block in BGP
router bgp 65000
no synchronization
no auto-summary
network 192.168.1.128 mask 255.255.255.128
network 192.168.1.0 mask 255.255.255.128
network 192.168.1.0
neighbor 10.1.1.1 remote-as 65001
neighbor 10.1.1.1 prefix-list 101 out
neighbor 10.2.2.2 remote-as 65002
neighbor 10.2.2.2 prefix-list 102 out
ip route 192.168.1.0 255.255.255.128 Null0 250
ip route 192.168.1.128 mask 255.255.255.128 Null0 250
ip route 192.168.1.0 mask 255.255.255.0 Null0 250
ip prefix-list 101 seq 5 deny 192.168.1.128/25
ip prefix-list 101 seq 10 permit 0.0.0.0/0 le 32
ip prefix-list 102 seq 5 deny 192.168.1.0/25
ip prefix-list 102 seq 10 permit 0.0.0.0/0 le 32
This would announce 192.168.1.0/25 to AS 65001 and 192.168.1.128/25 to AS 65002. Additionally both ASes get the full address block (plus all other routes) to ensure connectivity for the full address block if one neighbor goes down.
Be aware however, that in the internet it is highly unlikely to get updates announced smaller than /24. Most large ISPs will block anything smaller than /24.
Hope this helps! please rate all posts.
Regards, Martin
Thanx Martin i will configure and i will test that
Thx Martin for the crisp explaination
khaderbasha
Hello Murali,
Have tried using med.
1.Tag a higher med to all the routes which you do not want to be reached from one backbone and announce it.
You can follow this procedure to all backbone routers and influence backbone to follow what you want. Again it depends on what attributes your ISP is checking or considering on their end.
You can use route-map to achieve this.
Khader
