Problem with DOT1X
mlada16548
Frequent Visitor
Frequent Visitor
i have two cisco C3650, in one of them i was configure sucessful 802.1x but in second i want use IBNS 2.0, im create tempalte for dot1x but when i configure port and restart then i have always this same information about cred fail. I'm using windows NPS, AD and CA, if i connect one host to first switch his authenticate sucesfull but in second when i use "show access-session" i see: Method Dot1x, Domain Unknown, Status UnAuth.
Thanks for help.
mlada16548
Frequent Visitor
Frequent Visitor
Ok i now what i have a problem, in secon switch im using wrong radius server name in configuration. Sorry for waisting your time.
Francesco Molino
Can you please share the configuration you did on the second switch?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
mlada16548
Frequent Visitor
Frequent Visitor
interface GigabitEthernet1/0/11
description ######
switchport mode access
switchport port-security violation restrict
switchport port-security mac-address sticky
switchport port-security mac-address sticky ####.####.####
access-session port-control auto
mab
dot1x pae authenticator
spanning-tree portfast
service-policy type control subscriber TEST
policy-map type control subscriber TEST
event session-started match-all
10 class always do-until-failure
10 authenticate using dot1x priority 10
event agent-found match-all
30 authenticate using dot1x priority 10
event authentication-failure match-first
event authentication-success match-all
10 activate service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
radius server radius
address ipv4 192.168.40.45 auth-port 1645 acct-port 1646 key ######
dot1x system-auth-control
dot1x auth-fail eapol
aaa authentication login default group radius local
aaa authentication enable default group radius
aaa authentication dot1x default group radius
aaa authorization exec default group radius if-authenticated
aaa authorization network default group radius if-authenticated
aaa accounting identity default start-stop group radius
aaa accounting system default start-stop group radius
mlada16548
Frequent Visitor
Frequent Visitor
in logg i have only one messange:
%DOT1X-5-FAIL: Switch 1 R0/0: sessmgrd: Authentication failed for client (xxxx.xxxx.xxxx) with reason (Cred Fail) on Interface Gi1/0/11 AuditSessionID C0A8230E00013533E1B44AC2
mlada16548
Frequent Visitor
Frequent Visitor
