Problem with SFR Firepower:
akash.tiwari
Hi Team,
I bought 5525 firepower services with SSD and Control license.
can anyone explain to me if I have SFR module up and remain IPS and CXCS not showing up, then do I need to install both modules or not.
Mod SSM Application Name Status SSM Application Version
ips Unknown No Image Present Not Applicable
cxsc Unknown No Image Present Not Applicable
sfr ASA FirePOWER Up 6.2.2-81
Mod Status Data Plane Status Compatibility
0 Up Sys Not Applicable
ips Unresponsive Not Applicable
cxsc Unresponsive Not Applicable
sfr Up Up
Mod License Name License Status Time Remaining
ips IPS Module Disabled perpetual
Francesco Molino
When you install sfr you need to uninstall ips and cxsc modules.
The documentation clearly says that these modules needs to be removed when moving to sfr.
https://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
