Problems with Crystal Reports on CSA 5.1
harshmat11
Hi Experts,I hv two Live similar CSA setups one in Test LAb and other in Pilot Project.I am using separate SQL servers as database.The problem is in my Pilot the Crystal reports are not working but in the Test LAb its working fine.I hv attached the Out of the Crystal report.
harshmat11
Hi Guys,Now my Crystal Reports are working fine.As per previous email reply from TOM to check the "Seagate Component services"I tried restating the webcompserver service but it did nothing and showed me status as "stopping"
Finally I restarted my Server and everything is working fine.
Thanks Tom for your earlier help over email.
You're welcome. Glad to see you in the forums too.
Tom
