RDP through L2L problems.
Cybervex3
Level 2
Level 2
Having a strange issue with RDP to an XP machine through a L2L tunnel.
Tunnel is between an ASA5505 and ASA5510. Site A 5510, Site B 5505
I have a handful of Win7 and XP Dev machines running on ESXi 4.1 within Site A.
Site B to Site A
  1. I can RDP to all Server 2008 and W7 machines(physical and virtual).
  2. I can also RDP to a physical XP machine.
  3. I can ping the XP VMs by name and IP successfully.
  4. I cannot RDP to the 5 XP VMs running on the ESXi 4.1 host
Site A to Site B
  1. I can RDP from the XP VMs on the ESXi 4.1 host to any machine within Site B.
  2. Within Site A I can RDP to these XP VMs
AnyConnect
  1. I can AnyConnect into Site A and RDP to the XP VMs
I have tried to Telnet on 3389 to the XP VMs with no success.
Any ideas?
Maykol Rojas
Have you check the MTU on the regular RDP using the IPsec tunnel? Fragmentation are known issues when using RDP across IPsec
Mike
Mike
Julio Carvajal
Hello Cybervex3,
This sounds like a fragmentation issue.
Can you do the following on Site A:
     crypto ipsec df-bit clear-df outside
Then try to connect, if this does not work change the MTU size manually
on the client to a value of 1300
Let us know the result,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Ran the command on Site A ASA
Set the MTU on the XP VM and the Machine I am trying to RDP from to 1300.  No changes
Please refer to the following documment :
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081e621.shtml#task1
We need to determine if this is a fragmentation issue, follow the Discover Fragmentation section
Julio
Julio Carvajal
