secure-login problem in firepower chassis manager CLI
fly
Level 7
Level 7
I need secure-login in firepower chassis manager CLI
How Can I avoid contact Cisco tac  and get response of  Challende String?
I don't have contract
Thank you
Tom
FP-MI-LAB# secure-login
Challenge String (Please copy everything between the asterisk lines exclusively):
Guj//wYAAADamWA2wwLwPYO87vRQUjX9laGkaJh9WUYGtto2lXqAWZ0987RGWE9T
LU5VTC1TTqQjcGQAAA==
DONE.
Please input your response when ready:
Your understanding is correct without TAC support/Cisco contract you wont be able to login secure-login. only way for you is to re-image with new version. or re-image with same old software and restore-config.
please do not forget to rate.
5 Replies 5
Marius Gunnerud
As far as I know, you cannot log into secure-login without TAC assistance.
Please remember to select a correct answer and rate helpful posts
I know,but I need to erase log file in log directory , because is full due to bug.
I don't have contract,
I think I only have one method , install new version software on firepower, format a new file system , and restore config
frustrated
You can also delete the log files from expert mode.
Check out this Field Notice for more info: https://www.cisco.com/c/en/us/support/docs/field-notices/704/fn70466.html
Also check out this bug and the workaround associated with it. https://bst.cisco.com/bugsearch/bug/CSCwb34240
Unfortunately we run ASA on firepower 2100, not ftp ,can’t open expert mode in ASA
we have to secure-login in firepower chassis manager cli.
we don’t have FMC
thank you
