SIP and ASA problem
jawwalit
Level 3
Level 3
hello,
i have a ASA 5510 with CSC module, and i have CCM 5.1, i configured IP trunk between the call manager and international call provider through internet using SIP protocol, and that is my configuration :
SA Version 7.2(1)
hostname Itisaluna-Firewall
domain-name Itisaluna.com
interface Ethernet0/0
nameif outside
security-level 0
ip address 255.255.255.248
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.82.3.10 255.255.255.0
interface Ethernet0/2
nameif backup
security-level 0
ip address 192.168.1.10 255.255.255.0
interface Management0/0
nameif management
security-level 100
ip address 10.82.4.10 255.255.255.0
management-only
b
access-list outside_access_in extended permit udp any host Voice_GW_REAL eq sip
access-list outside_access_in extended permit tcp any host Voice_GW_REAL eq sip
access-list VGW extended permit udp any any eq sip
access-list VGW extended permit tcp any any eq sip
p
static (inside,outside) Voice_GW_REAL CCM_private netmask 255.255.255.255
access-group outside_access_in in interface outside
class-map inside-class
match access-list inside_mpc_in
class-map SIP-TRAFIC
match access-list VGW
class-map RTP-TEST
match rtp 16384 554
class-map outside-class
match access-list outside_mpc_in
policy-map global_policy
class SIP-TRAFIC
inspect sip
policy-map outside-policy
class outside-class
csc fail-open
class RTP-TEST
policy-map inside-policy
class inside-class
csc fail-open
service-policy global_policy global
service-policy outside-policy interface outside
service-policy inside-policy interface inside
my problem is that when i make an international call , i hear the person who i talk , but he didnt hear me, can you please help me for this case
umedryk
Level 11
Level 11
When Mobile Agent local/remote CTI ports are located on different clusters and a SIP trunk is used to connect the clusters, "MTP required" must be checked on at least one side of the SIP trunk in order for Mobile Agent to Mobile Agent calls to work between the clusters. H.323 trunks do not require an MTP for Mobile Agent to Mobile Agent calls
