Source Fire Connection Events not showing/recording
NandoNaldo48693
I have noticed that suddenly all the Source Fire Connection Events not showing/recording.
If i try to expand the time window i can the last data shown will be since 03 Jan 2020
I have changed the Maximum Connection Summaries in Database settings in 2000000
Last error i had was the error about network time protocol. But i have fixed that
Please anyone could help ?
thank you
Abheesh Kumar
Normally FMC purge the connection events when it hits the threshold. Depends upon the logging in ACP & the number of connections in your environment this may exceed the connection threshold.
Which Model of FMC you have...??
Hope This Helps
Abheesh
Model:
3D7030 / Virtual Defense Center 64bit/
Software Version
5.3.1.6 (build 16)
Model:
Software Version
5.3.1.6 (build 16)
