TCP Reset -I ASA Packet capture output and Mac address info
mahesh18
Level 6
Level 6
Hi Everyone,
I was troubleshooting the ASA issue where user was getting TCP reset I
I did packet capture on both directions and when i check packet detail it showed vlan info and 2 mac addresses with message FLAG R.
I found that first mac address  and vlan info was of next hop IP address and second mac address was of another firewall which was sending the Reset.
Need to confirm with experts here that TCP Reset I always show mac address of next hop and device which send the request?
MAhesh
Vibhor Amrodia
So , what you would have seen would be Src/Dest IP address , Src/Dest MAC address.
Now , if the Source VLAN from where the RESET is coming is in the same subnet as the ASA interface on which the traffic is seen , then the SOURCE VLAN device is sending the RESET otherwise if the SOURCE VLAN information is in different Subnet , then the RESET is being relayed by the L3 Hop in between.
If you can post the actual logs or snap , i would be able to relate it in a better way for you.
FYI:- TCP RESET-I will only be seen when the RESET flag is received from the device on the higher Security Interface.
Thanks and Regards,
Vibhor Amrodia
Vibhor Amrodia
Thanks and Regards,
Vibhor Amrodia
Many thanks
MAhesh
