VPN Connecting Problem
pranuv.pandit
Community Member
Hi all
I have configured PAT on my ASA-5510 for internet access by the internal LAN users. Now the users on the internal LAN are able to access the internet but they are not able to connect to a Remote Network by using a VPN client. Earliar I had configured NAT in the Windows server through Routing and Remote Services. Everything was working fine.I was using only a single public IP there also but now with the ASA I am facing problem. Please help.
gbudd12345
Level 2
Level 2
you probably want to add "inspect ipsec-pass-thru" to your inspection lists. That might help that issue.
--Gavin Budd
