Why does ASA block icmp by default and not other traffic?
reachabdulla
Imagine an ASA with a web server on the "outside" and a PC on the "inside". By default, when we ping from "inside" PC to "outside" Server, the traffic is blocked. We need to apply ACL on the outside to permit the icmp.
On the contrary, if we try to access a web page of "outside" Server from "inside" PC, its permitted by default.
I am not able to understand why?
Thanks in advance.
Mohammed Abdulla.
Jon Marshall
Thanks in advance.
Mohammed Abdulla.
Mohammed
Have a quick read of this thread - the bit that explains the basic function of an ASA firewall -
ASA basic function
The difference with ping is it uses ICMP and ICMP is not stateful in the way that TCP/UDP are (UDP is pseudo-stateful). Any protocol that isn't stateful needs it's traffic explicitly allowed back in unlike the http example in the above thread. That's why you have to allow ICMP back in.
However it should be noted that the ASA and pix firewalls with v7.x code  have the ability to do ICMP inspection which if you enable it means you don't need to allow it back in with an acl. Have a read of this link which covers ICMP through the ASA -
ASA ICMP
Jon
Jon Marshall
Thanks in advance.
Mohammed Abdulla.
Mohammed
ASA basic function
ASA ICMP
Jon
