exfat65
Hy everybody,
after an eletrical issue, my Cisco switch doesn't boot anymore.
It only shows speed led on the left and trunk port leds on the right, they all are fix orange on.
Can anyone tell me what is the trouble and if there is a chance to resume it?
At the moment, no activity and no response via console.
Thank you to all...
Mark Malone
if the console is dead , the board may have blown during the outage
is teh device under support to RMA , iyt may need to be replaced ?
without console access there is nothing you can do
exfat65
ok, thank you...
cmarva
Level 4
Level 4
and not to rain on your parade, but I believe the 2960G is past LDoS so I don't think you can get a replacement
