zivx
I tried to setup a virtual environment with 2960 switches and 2911 Router.
In one part of the network where I connected PCs directly to the 2911 Router, I was able to communicate to the attached devices, having configured static route.
In the the other network, I interconnected the PCs with switches prior to connecting to the router (2911). I have setup the static route just as in the smaller network but the PCs are not able to the reach each other beyond the router.
I have attached the network file. Can someone pls look at it and confirm what could be wrong with the setup.
Martin L
It works fine except PC 10 is missing something. if u not sure, check and compare with other PCs.
1st ping may fail due to ARP, you must re-ping.
Martin L
Remember: routers do know about their direct connected interfaces and networks. see routing table with show ip route table . If routes are there, there is no need to add static routes for those listed as directly connected. If route is not in routing table, then u must add static route or enable dynamic routing protocol with neighbor to get it dynamically.
zivx
@Martin L
Big Thanks. I missed to configure the default gateway. I also tried to remove the not-neccessary static routes configuration as you advised communication. Everything works now.
Martin L
glad to help
