hi anybody! can you help to fix this problem?
on primary router (hub)
Oct 1 08:57:50.242: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.1.2 on Tunnel11 from LOADING to FULL, Loading Done
Oct 1 08:57:50.242: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.1.3 on Tunnel11 from LOADING to FULL, Loading Done
Oct 1 08:58:38.286: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.1.2 on Tunnel11 from FULL to DOWN, Neighbor Down: Dead timer expired
Oct 1 08:58:40.014: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.1.3 on Tunnel11 from FULL to DOWN, Neighbor Down: Dead timer expired
Oct 1 08:58:47.826: %OSPF-5-ADJCHG: Process 1, Nbr 10.0.1.2 on Tunnel11 from LOADING to FULL, Loading Done
primary router
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key cisco address 0.0.0.0 0.0.0.0
crypto ipsec transform-set TS esp-3des esp-md5-hmac
mode transport
crypto ipsec profile DMVPN
set transform-set TS
interface Tunnel11
ip address 10.0.1.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 123
ip nhrp holdtime 60
ip ospf network broadcast
ip ospf priority 200
ip ospf mtu-ignore
delay 5
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 123
tunnel protection ipsec profile DMVPN
interface GigabitEthernet0/0
description LAN
ip address 10.100.1.1 255.255.255.252
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description WAN
ip address 10.200.1.2 255.255.255.252
duplex auto
speed auto
router ospf 1
router-id 10.0.1.1
redistribute connected
network 10.0.1.0 0.0.0.255 area 0
network 10.200.1.0 0.0.0.3 area 0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 10.200.1.1
backup router
encr aes
group 2
mode transport
interface Tunnel22
ip address 10.0.2.1 255.255.255.0
no ip redirects
ip nhrp network-id 456
ip nhrp holdtime 60
ip ospf priority 100
ip ospf mtu-ignore
delay 10
tunnel key 456
description LAN
ip address 10.100.1.5 255.255.255.252
shutdown
duplex auto
speed auto
description WAN
ip address 10.200.1.5 255.255.255.252
duplex auto
speed auto
router ospf 1
router-id 10.0.2.1
redistribute connected metric-type 1 subnets route-map static-to-ospf
network 10.0.2.0 0.0.0.255 area 0
network 10.100.1.4 0.0.0.3 area 0
network 10.200.1.4 0.0.0.3 area 0
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1 10.200.1.6
spoke 1
encr aes
group 2
mode transport
interface Tunnel11
ip address 10.0.1.2 255.255.255.0
no ip redirects
ip nhrp map 10.0.1.1 10.200.1.2
ip nhrp map multicast 10.200.1.2
ip nhrp holdtime 60
ip nhrp nhs 10.0.1.1
ip ospf mtu-ignore
delay 5
tunnel source FastEthernet4
tunnel key 123
tunnel protection ipsec profile DMVPN shared
interface Tunnel22
ip address 10.0.2.2 255.255.255.0
no ip redirects
ip nhrp map 10.0.2.1 10.200.1.5
ip nhrp map multicast 10.200.1.5
ip nhrp holdtime 60
ip nhrp nhs 10.0.2.1
ip ospf mtu-ignore
delay 10
tunnel key 456
interface FastEthernet4
description WAN
ip address 10.200.1.9 255.255.255.252
duplex auto
speed auto
router ospf 1
router-id 10.0.1.2
log-adjacency-changes
network 172.22.38.0 0.0.0.255 area 0
ip route 0.0.0.0 0.0.0.0 FastEthernet4
spoke 2
encr aes
group 2
mode transport
interface Tunnel11
ip address 10.0.1.3 255.255.255.0
no ip redirects
ip nhrp holdtime 60
ip ospf mtu-ignore
delay 5
tunnel key 123
interface Tunnel22
ip address 10.0.2.3 255.255.255.0
no ip redirects
ip nhrp holdtime 60
ip ospf mtu-ignore
delay 10
tunnel key 456
description WAN
ip address 10.200.1.13 255.255.255.252
duplex auto
speed auto
router ospf 1
router-id 10.0.1.3
network 172.23.48.0 0.0.0.255 area 0
Thanks a lot,
Eric
Can you try:
conf t
int tun 2
ip ospf network point-to-multipoint
ip ospf mtu-ignore
do the same for all spoke
Let see how it go
Good luck
