rhurst
Check Hardware Troubleshooting Index Page for additional recommendations:
http://www.cisco.com/en/US/partner/products/hw/routers/ps214/products_tech_note09186a008012fb88.shtml
Part Numbers selecionados (Selected Part Numbers)
Product Family
Product ID
Product Family
Product ID
7600
7600-ES+20G3C
ASR9000
A9K-2KW-DC
7600-ES+20G3CXL
A9K-2T20GE-B
7600-ES+2TG3CXL
A9K-2T20GE-L
7600-ES+4TG3C
A9K-40GE-B
7600-ES20-10G3C
A9K-40GE-L
7600-ES20-10G3CXL
A9K-4T-B
7600-SIP-200
A9K-4T-L
7600-SIP-400
A9K-8T-B
7600-SIP-600
A9K-8T-L
76-ES+T-20G
A9K-RSP-4G
76-ES+XC-20G3C
CRS
CRS-FP140
RSP720-3C-GE
CRS-MSC-140G
RSP720-3CXL-GE
CRS-MSC-B
C6000
WS-SUP720-3B
MGX
MGX-RPM-PR-512
WS-SUP720-3BXL
MGX-VXSM-155
ASR5000
ASR5K-PSC-32G-K9
MGX-VXSM-T1E1
ASR5K-PSC-64G-K9
PXM45/C
GSR
12000-SIP-401
UBR10K
UBR10-MC5X20H-D
12000-SIP-601
UBR-MC20X20V-20D
PRP-2
UBR-MC20X20V-5D
C3560
WS-C3560-48PS-S
ESR-PRE4
C3750
WS-C3750G-48TS-S
Basic steps to verify below PIDs
Diagnostics needed to be gathered & attached to the RMA
7600, C6000, GSR, ASR9000,CRS, C3560,C3750
  • Verify Memory by replacing with Known good Memory
        Describe Physical Condition (LED Colors & Status)
  • Describe what was found/investigated to identify the hardware failure. (i.e What outputs suggests it’s the hardware?)
  • Attach Login details to SVO RMA (admin/IPaddress)
  • Show tech output
  • Logs from logging/snmp server (when available)
ASR5K
  • Describe  Physical condition (LED Colors and Status)
  • Show support details (SSD)
UBR10K
  • Describe Physical Condition (LED Colors & Status)
  • Show tech output
  • Show logs output for the day the problem happened (if not available , pull the SYSlogs )
  • If modems falling offline on a line card we would need the below output
    • show tech cmts cable x/y/z
    • Show cable hop  (5 times)
    • Show controller cable x/y/z up  | inc SNR  (5 times)
    • Crash files from line card (where applicable)  - Below are Instructions
      • Enable service internal First
      • Router(Config)# service internal
      • (config)# end
      • telnet to MC5x20 card:
      • Router#telnet 127.0.0.51     ( you might have to source from the Ethernet)
For XX:
==>.50 for card 5/0
==>.51 for card 5/1
==>.60 for card 6/0
==>.70 for card 7/0
==>.71 for card 7/1
==>.80 for card 8/0
==>.81 for card 8/1
  • "term len 0"
  • "show tech" from the line card (Make sure you are enable mode in the card)
  • Do a "dir bootflash:" to see the crashinfo files on the bootflash of the card, if there are multiple crashfiles you can match the timestamp with latest crash file. Once you know the name of crash file. To collect that crashinfo file do "more bootflash:<file_name>"
MGX
  • Provide outputs of the following Commands
    • Dspcds
    • dspcd  <  problematic slot >
    • dsprevs
    • dsprevs -s
    • dsprmrsrcs
    • dsplog
    • dsplog -sl  < problematic slot  >
    • dsperrs
    • dsperr -sl   <  problematic slot   >  -en  <error # >
    • dsperrs -sl  <  problematic slot  >
    • dsperrhist   < problematic slot  >
    • show tech from RPM module
    • show log from RPM module
    • on pxm45C  go to shellconn
    • shmCsmTraceShow  < problematic slot   >
    • showCd   < problematic slot   >
    • dspclkalms
    • dspclksrcs
    • dspcurclk
    • dspclockinfo (from shellConn)
Diagnósticos que precisam ser coletados e anexados ao RMA
  • Verifique a memória trocando-a por um pente que esteja funcionando
  • Descreva a condição física (Cores e status dos LED)
  • Descreva o que foi encontrado/investigado para identificar a falha de hardware (ex: Que output sugere que a falha é de hardware?)
  • Anexe detalhes de Login ao RMA no SVO  (admin/IPaddress)
  • Show tech output
  • Logs do servidor de logging/snmp (se disponível)
ASR5K
UBR10K
  • Show tech output
  • Show logs output do dia em que o problema ocorreu (se não estiver disponível , forneça o SYSlogs )
  • Se o modem está falhando offline em um line card nós precisamos do output abaixo:
    • Show cable hop  (5 vezes)
    • Show controller cable x/y/z up  | inc SNR  (5 vezes)
    • Crash files do line card (onde for aplicável)  - Abaixo seguem as instruções
      • (config)# end
      • Router#telnet 127.0.0.51     ( você talvez precise gerá-lo da Ethernet)
For XX:
==>.50 for card 5/0
==>.51 for card 5/1
==>.60 for card 6/0
==>.70 for card 7/0
==>.71 for card 7/1
==>.80 for card 8/0
==>.81 for card 8/1
  • "term len 0"
  • "show tech" da line card (Tenha certeza que o modo na line card está ativo)
  • Rode um "dir bootflash:" para visualizer os arquivos de crashinfo no bootflash do cartão, se houver múltiplos crashfiles você pode conferir a data com o crashfile mais recente. Uma vez que você souber o nome do crashfile, rode "more bootflash:<file_name>" para coletar o crashinfo
MGX
  • Descrição do que foi encontrado/investigado para identificar a falha de hardware (ex: Que output sugere que a falha é de hardware?)
  • Forneça outputs dos seguintes comandos
    • Dspcds
    • dsprevs
    • dsprevs -s
    • dsprmrsrcs
    • dsplog
    • dsperrs
    • show tech do RPM module
    • show log do RPM module
    • dspclkalms
    • dspclksrcs
    • dspcurclk
