Introduction
This document demonstrates how to troubleshoot OSPFv3 fail to form neighbor adjacency when configured using Frame-Relay.The OSPFv3 uses Link-local address to form neighbor adjacency by sending and receiving the hello packet to the neighbor router.While configuring OSPFv3 using Frame-Relay one should remember the difference that the DLCI mapping should be done for the Link-local addresses.The OSPFv3 neighbor adjacency will not be formed, until their link-local addresses are mapped to the appropriate DLCI's.
Prerequisite
It is assumed that the reader has an understanding of OSPFv3 and Frame-Relay..
Background Information
The two routers (R1and R2 ) in the network diagram are connected to a frame-relay switch via serial interfaces communicate with each other using OSPFv3.The routers are configured with loopbacks and OSPFv3 is advertised on each interface using the command ipv6 ospf <process id> area <area id>.
Topology Diagram
Configuration
Note: All configurations are tested on Cisco 7200 Router running IOS 15.0(1)M5 software.
Router R1Router R2
| R1#show run Building configuration... ! version 15.0 ! hostname R1 ! ipv6 unicast-routing ipv6 cef ! interface Loopback0 no ip address ipv6 address AA00::1/128 ipv6 ospf 1 area 0 ! interface Loopback1 no ip address ipv6 address AA01::1/128 ipv6 ospf 1 area 0 ! interface Serial1/0 no ip address encapsulation frame-relay ipv6 address 1011:1:1:1::11/64 ipv6 ospf network broadcast ipv6 ospf 1 area 0 serial restart-delay 0 frame-relay map ipv6 1011:1:1:1::12 101 broadcast ! ipv6 router ospf 1 router-id 1.1.1.1 log-adjacency-changes ! ! end | R2#show run Building configuration... ! version 15.0 ! hostname R2 ! ipv6 unicast-routing ipv6 cef ! interface Loopback0 no ip address ipv6 address BB00::1/128 ipv6 ospf 1 area 0 ! interface Loopback1 no ip address ipv6 address BB01::1/128 ipv6 ospf 1 area 0 ! interface Serial1/0 no ip address encapsulation frame-relay ipv6 address 1011:1:1:1::12/64 ipv6 ospf network broadcast ipv6 ospf 1 area 0 serial restart-delay 0 frame-relay map ipv6 1011:1:1:1::11 202 broadcast ! ! ipv6 router ospf 1 router-id 2.2.2.2 log-adjacency-changes ! ! end |
Problem
In the above configuration, the frame-relay DLCI mapping is done to the IPv6 global address. To verify the ospfv3 neighbor adjacency use the command show ipv6 ospf neighbor in router R1.
The above output shows that the hellos are being sent and received the OSPF peers and DR/BDR election has happened but still the routers are in EXSTART state.
Using debug commands, debug ipv6 ospf adj  and debug ipv6 ospf hello debug the adjacency events and hello events.
The above debug output confirms that the hellos are being sent and received by OSPFv3 peers. R1 send the DBD database description packets to router R2 but never receives acknowledgement.The EXSTART state indicates that the DR/BDR election has happened and initial DBD packet is sent.
Resolution
The reason is OSPFv3 uses link-local address to exchange packets as its shown in the above debug output.The DLCI mappings has to changed to fix this issue. The frame-relay mappings has to be done for the link-local address of the neighbor router. The DLCI mappings are changed in the serial interface S1/0 on both the routers R1 and R2 as shown below:
You can see that as soon the DLCI mapping is done correctly to the link-local address of the neighbor, the OSPFv3 neighbor adjacency is formed between the routers R1 and R2.
Verify
To verify the the routers receives the routes via OSPFv3 use the command show ipv6 route ospf
The above output shows that the routes are successfully received by both routers R1 and R2.
References
Implementing OSPFv3
Cisco IOS IPv6 Command References
Sample Configuration for OSPFv3
