03-01-2017 12:52 PM - edited 03-10-2019 12:47 AM
Can we use certificates for authentication when implementing 802.1X on the LAN?
Thanks in advance.
Best, ~zK
Solved! Go to Solution.
03-01-2017 02:56 PM
There is no easy answer ...
03-01-2017 01:56 PM
Certificates can be used regardless of the access-method (wired, wireless, VPN).
All you need to do is enroll your endpoints/users with certificates and make sure that both the ISE and the endpoints trust your root. Based on your tools to enroll the endpoints with certificates, using PEAP could be an option. There the endpoints only need the root-certificate and the ISEs need an identity certificate.
03-01-2017 02:48 PM
Thanks for the quick response, Karsten!
Which auth protocol should we use for the wired 802.1X: EAP-TLS, EAP-FAST, or PEAP?
Best, ~zK
03-01-2017 02:56 PM
03-02-2017 10:08 AM
That's very helpful!
- We've a mix of PANs and ASAs client VPN implementations, so we have clients with Anyconnect and clients with GlobalProtect.
- Yes, we do have an enterprise PKI in place, so I guess we will consider EAP-TLS
I found this blog, which might be helpful for others who might stumble on this post, that compares and explains the differences between the EAP auth methods: http://www.networkworld.com/article/2223672/access-control/which-eap-types-do-you-need-for-which-identity-projects.html
Thanks again.
Best, ~zK
