AJ: Cant surf when using proxy
ajarina
Level 2
Level 2
I have a PIX 501 connected to a DSL line and heres the scenario:
If i connect the PIX inside interface directly to a workstation, I would be able to surf and access the internet witout a problem.
But if ill use a proxy to connect between the PIX and the local network, I cant get the workstation to connect to the Internet. My proxy is using wingate and in the local network I have 3 different networks that can access each other. Here is somt troubleshooting that i tried.
From the proxy, I can ping to the inside networks. I can also ping to the PIX inside IP address also but I cant ping to the next hop address in the outside(gateway of PIX). Is there some issue with Wingate or some routing that I need to do? Please advise. Thanks.
gfullage
Do you add routes onto the PIX pointing to the intenal networks, with the proxy as the next hop?
jmia
Level 11
Level 11
Have you got any access-list placed on you PIX ?
i.e. access-list inside permit tcp host any eq www
Let me know...
Jay.
im not hosting a web server so i dont use access-list for www but i do have this to check connectivity.
access-list inbound permit icmp any any
access-group inbound in interface outside
