Concentrator administration via public HTTPS
mattcooling
Level 2
Level 2
Before SSL-VPN, we could configure a concentrator to be administered via the public IP address over HTTPS, and utilise filters to lock down access to that port to a specific IP range.
When SSL-VPN is configured for a concentrator, HTTP and HTTPS access are permitted from all locations - and present the WebVPN interface. However, it is not possible to navigate to /admin.html on that interface, in order to perform administration. Is this normal?
If so, then there a number of options
a) administer the concentrtator via the private IP address when connected over a remote access VPN - no use if the remote access VPN isn't working for some reason
b) configure different ports for the SSL-VPN and administration interfaces - is this possible, and if so, how?
c) permit access to /admin.html via the public interface - is this possible, and if so, how?
Any suggestions/advice on this would be much appreciated.
Matt
Excellent - works a treat - thanks
