07-14-2003 03:18 AM - edited 03-09-2019 04:01 AM
I had deploy 3 IDS Sensor (4235) in my network. I have some question that I am doubt with:
a) did the IDS sensor drop any packet that it detected as an attack?
b) when I log into the IDS Sensor's web-base administration page, I saw something like "Signature Objects: 1058 -- Deleted: 2644239" under sensing interface statistics. what does this means?
c) how do I set blocking thru router ACL? Any guideline available on the net?
Solved! Go to Solution.
07-14-2003 08:38 AM
a) The IDS does not drop any packets. On detection of an attack packet (signature), it can initiate the ACTION that has been configured for that signature. e.g. block, reset, log. In case of block or reset, the IDS will configure an ACL on the blocking device so as to stop these packets from the host.
But in all this, the IDS is not dropping any packets. It still keep looking/sniffing all packets.
b) This means that since the system has been active it has deleted (expired
or completed inspection on) 2644239 objects and that there are currently 1058
active signature objects in the database. Doesn't really mean much to you
and really helps the development engineers determine realtive load on the
sensors.
c) What management platform are you using and what is the IDS version?
If you are using VMS for management;
If IDM/IEV4.0, then goto the below url
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids9/idmiev/swchap3.htm#593299
If IDM/IEV 3.x then the below;
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids8/13876_01.htm#xtocid49
yatin
07-14-2003 08:38 AM
sensors.
yatin
07-14-2003 05:59 PM
your info are really helpful! thank you very very much!
