Failover Hostname
normanzhang
Level 3
Level 3
Can failover PIX boxes have differ hostname? Or they need to be the same?
jackko
Level 11
Level 11
i would think so, as the fo unit sync with the primary unit including all the codes ann the command hostname is part of it.
Patrick Iseli
Level 11
Level 11
Usually the hostname is identical in failover configuration.
See the following guide:
Note: This guide bellow will not cover version 7.x.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094ea7.shtml
sincerely
Patrick
jackko
Level 11
Level 11
You are 100% right, hostname has to be the same for the HA pair.
