Initial Setup For IDS
Randa11Villalobos
Community Member
Simple question:
I want to configure my IDS
Cisco Systems Intrusion Detection Sensor, Version 4.1(1)S47
Platform: IDS-4215
I need some step by step links on how to accomplish this via CLI or GUI.
Also some links to read to understand how this device exactly works.
I already have the ip and the username..that's about it 😉
nkhawaja
you simply need to run "setup" and follow the prompts. sensor usually has two ports , 1 command and control, 2) Sniffer port.
you need to connect teh sniffer port to a hub or a switch where you want to detect the attack.
irelandsky
Level 3
Level 3
You have also to update your IDS signature via CLI ( upgrade command ) or via IDM ( connect https://ip-ISD)
For first quick config follow this link
http://www.cisco.com/en/US/products/sw/secursw/ps5052/products_quick_start09186a00801b10ec.html
Hope this help
Marco
