Mailserver front-end/back-end problem
fembsen
I have got an Exchange 2000 front-end/back-end configuration where both servers are on seperate interfaces of a PIX 515. The front-end is on a lower security level.
When I use PIX IOS 6.1.1 everything works fine but when I use a later version of PIX IOS the front-end server won't start properly. That is, the information store (and thus IMAP4 and POP3) won't start.
Is this a new 'feature' in the later PIX IOS versions, are there some new commands that I need to use, is it a bug in the PIX IOS versions? Can anyone tell me what causes this problem?
I hope someone can help me with this.
Regards, Frank
6 Replies 6
yusuff
The implementation is no different in newer versions of PIX. Double check your config and that you have the required ports/static translation configured correctly. Check what the logs say. If you still think it is a problem, open a TAC case and they should be able to investigate in detail. There are slim chances that it could be a bug though.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/config/msexchng.htm
R/Yusuf
fembsen
Thanx for the info but I have tried about everything I could think of. I even set the PIX 'wide open' and it still wouldn't work. I have looked at logs and network traces but they don't show anything that hints a problem.
Again thanx for the info, Frank
We have the same problem. Im using PIX501. Everybody can surf except for the email functionality. When I try to enter the static translation, the mail server then stops surfing. Ive been reading lots of articles and I just entered the right commands based on that article. I dont know what im missing here. Please email ([email protected]) me if you able to find the answer. Thnks.
svarughe
Visitor
open up the fowwling ports
make sure you open up
445 (TCP) - Server message block (SMB) for Netlogon, LDAP conversion and distributed file system (Dfs) discovery.
3268 (TCP) - LDAP to global catalog servers.
389 (TCP, UDP) - Lightweight Directory Access Protocol (LDAP).
135 (TCP) - EndPointMapper.
123 (TCP) - Windows Time Synchronization Protocol (NTP).
88 (Transmission Control Protocol [TCP], UDP) - Kerberos authentication
53 (Transmission Control Protocol [TCP], User Datagram Protocol [UDP]) - Domain Name System (DNS).
make the this change to the registry
Locate the following key in the registry:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\NTDS\Parameters
On the Edit menu, click Add Value, and then add the following registry value:
Value Name: TCP/IP Port
Data Type: REG_DWORD
Radix: Decimal
Value: greater than 1024
and
using active directory sites and tools
create a site name and subet for the dmz
dtorre
Community Member
Yes, after 6.1 versione Cisco added a new fixup feature for the LDAP protocol.
That's your problem.
LDAP fixup is blocking proper communication between front end and back end.
Disable it, it will work.
C.
Thanx very much. That was the answer I was looking for.
