Problems with access-lists
thechicco
Hey all.
Currently having problems with my access lists. I'm trying to forward (allow) port 35000 from outside to an internal host. However when I do this it knocks out my incoming mail rule (port 25) to the dmz.
It seems I cannot have
access-group outside_mail in interface outside
at the same time as
access-group torrent in interface outside
Outside: 212.x.x.93 (all internal PAT'ed to this)
DMZ: 172.16.1.0/24
Internal: 10.0.1.0/24
212.x.x.92 mail server nated to 172.16.1.1
config:
PIX Version 7.1(1)
hostname XXXXXXXX
domain-name XXXXXXXXXXXXXX
enable password XXXXXXXXXXXXXX encrypted
names
name 10.0.10.0 VM_Management
interface Ethernet0
nameif outside
security-level 0
ip address XXXXXXXXXXXXX 255.255.255.240
interface Ethernet1
nameif inside
security-level 100
ip address 10.0.1.251 255.255.255.0
interface Ethernet2
shutdown
no nameif
security-level 99
no ip address
<--- More --->
interface Ethernet3
shutdown
no nameif
security-level 90
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
nameif dmz
security-level 50
ip address 172.16.1.251 255.255.255.0
passwd XXXXXXXXXX encrypted
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns server-group DefaultDNS
domain-name XXXXXXXXXXXXXXXXX
access-list outside_mail extended permit tcp any host 212.x.x.92 eq smtp
access-list mail_outside extended permit tcp host 172.16.1.1 any eq smtp
access-list dmz_dns_outside extended permit tcp host 172.16.1.1 any eq domain
access-list dmz_dns_outside extended permit udp host 172.16.1.1 any eq domain
access-list dmz_mail_outside extended permit tcp host 172.16.1.1 any eq smtp
access-list dmz_www_outside extended permit tcp host 172.16.1.1 any eq www
access-list torrent extended permit udp any any eq 35000
access-list torrent extended permit tcp any any eq 35000
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
no failover
asdm image flash:/asdm-511.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
static (inside,outside) udp interface 35000 10.0.1.40 35000 netmask 255.255.255.
255
static (inside,outside) tcp interface 35000 10.0.1.40 35000 netmask 255.255.255.
255
static (inside,dmz) 10.0.1.0 10.0.1.0 netmask 255.255.255.0
static (dmz,inside) 10.0.2.0 10.0.2.0 netmask 255.255.255.0
static (dmz,outside) 212.33.100.92 172.16.1.1 netmask 255.255.255.255
static (inside,outside) 212.33.100.91 10.0.1.15 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 212.33.100.94 1
route inside VM_Management 255.255.255.0 10.0.1.251 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
inspect dns maximum-length 1000
service-policy global_policy global
Cryptochecksum:xxx
: end
rico_hao40
You are right. with one direction (in or out), only one access-group on a interface.
access-list outside_mail_torrent extended permit tcp any host 212.33.100.92 eq smtp
access-list outside_mail_torrent extended permit udp any any eq 35000
access-list outside_mail_torrent extended permit tcp any any eq 35000
access-group outside_mail_torrent in interface outside
thanks rico.
so anything coming in from outside I have define and encompass all in one access-group?
e.g
port 45000 into inside
port 25 into dmz
port 80 into dmz
all have to be put in say outside_coming_in and applied via access-group outside_coming_in interface outside?
seems a bit limited :)
Yes. After the incoming traffic passed ACL then the pix routing table will send the traffic to the right interface (inside or dmz).
