02-17-2004 10:34 PM - edited 03-09-2019 06:27 AM
Not sure if this is in the right section?
I am having problems with the telneting the router in my network.
There are about 10 sites with routers, i remotely conenct to different sites throught there servers. I connect to a server and then run a telnet session to try and connect to the router but everytime i try says "router unavailable on port 23". There is only one router out of the whole ten i can telnet to from the local server. I need to be able to telnet from the local server and from the servers in the main base.
Here is the config for the routers that i cant telnet to, the second config is for the router i can telne to locally.
1st>>>
line vty 0 4
access-class 70 in
exec-timeout 0 0
password 7 (*************)
transport input ssh
access-list 70 remark Modem Management
access-list 70 permit 10.0.0.0 0.0.255.255
access-list 70 permit 10.10.0.0 0.0.255.255
2nd>>>>>> i can telnet to
line vty 0 4
access-class 70 in
exec-timeout 0 0
password 7 (**************)
transport input ssh
I didnt originally setup routers and only have to get them telneting so i can then hand the service of them to new company.
Cant understand why not working, if unable to resolve soon i have many old pcs laying around to use a deticated pcs to connect up the router directly through console port but would just like to have telnet.
02-18-2004 11:36 AM
I am not entirely clear on your situation. It sounds like you can connect to 9 of the 10 routers. For the one you cannot connect to, I would guess there is a firewall or some other device blocking access to port 23.
02-20-2004 12:19 AM
I cant connect to 9 out of the 10 routers from the server at that site. Cant connect to any from the main site. There are no firewall restrictions, if there was i would still be able to telnet from the local server i think?, but have made sure no firewall restrictions. Was wondering if there are any timeouts.
I didnt set these routers up and we have had a few other issues that were hard to work out because of the person who configured.
03-19-2004 08:24 AM
take of the transport in ssh, you dont need it and it could be restricting your telent... ssh is NOT telnet
03-25-2004 12:24 PM
You config only permits ssh, but instead of permitting telnet if I dont have to I would keep "transport input ssh" and use openssh or putty to hit my routers.. Why have your ID/Password cleartext if you dont have to?
http://kputty.sourceforge.net/ kputty for linux
http://putty.bhni.net/ windows putty
03-25-2004 12:24 PM
Your config only permits ssh, but instead of permitting telnet if I dont have to I would keep "transport input ssh" and use openssh or putty to hit my routers.. Why have your ID/Password cleartext if you dont have to?
