routing problems
rmeder
Community Member
I have a 2 PIX 501s. PIX-1 has it's inside interface on the network 192.168.x.0 and PIX-2 has it's inside interface on the network 10.0.x.0 and outside interface on 192.168.x.2 which are both internal lans. I need to setup a route from 192.168 to the 10.0 I added a route to the config which I figured would accomplish this, but when I try to telnet from the 192.168 to the 10.0 I receive a syslog error stating that a route to 10.0.x.100 does not exist from 192.168.x.10. This error is from PIX-1 The following is the config of PIX-1
Result of firewall command: "sh run"
: Saved
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password XXXX encrypted
passwd XXXX encrypted
hostname PIX-1
domain-name nexstore.internal
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.x.0 Remote_PIX_Corporate
access-list 101 permit tcp any host 216.xx.xx.70 eq https
access-list 101 permit tcp any host 216.xx.xx.70 eq 3389
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any echo-reply
access-list 101 permit tcp any host 216.xx.xx.71 eq pcanywhere-data
access-list 101 permit tcp any host 216.xx.xx.71 eq 5632
access-list 101 permit tcp any host 216.xx.xx.71 eq https
access-list inside_outbound_nat0_acl permit ip any 10.x.0.96 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 10.x.0.96 255.255.255.224
access-list nexstore_splitTunnelAcl permit ip Remote_PIX_Corporate 255.255.255.0 any
pager lines 24
logging on
logging trap debugging
logging host inside 192.168.x.10
mtu outside 1500
mtu inside 1500
ip address outside 216.xx.xx.66 255.255.255.240
ip address inside 192.168.x.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool remote_IP 10.x.0.100-10.x.0.119
pdm location 192.168.x.10 255.255.255.255 inside
pdm location 192.168.x.12 255.255.255.255 inside
pdm location 192.168.x.11 255.255.255.255 inside
pdm location Remote_PIX_Corporate 255.255.255.0 outside
pdm location 10.0.x.100 255.255.255.255 inside
pdm location 10.0.x.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp 216.xx.xx.70 https 192.168.x.12 https netmask 255.255.255.255 0 0
static (inside,outside) tcp 216.xx.xx.70 3389 192.168.x.12 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp 216.xx.xx.71 pcanywhere-data 192.168.x.11 pcanywhere-data netmask 255.255.255.255 0 0
static (inside,outside) tcp 216.xx.xx.71 5632 192.168.x.11 5632 netmask 255.255.255.255 0 0
static (inside,outside) tcp 216.xx.xx.70 3390 192.168.x.11 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp 216.64.81.71 https 192.168.x.11 https netmask 255.255.255.255 0 0
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 216.xx.xx.65 1
route inside 10.0.x.0 255.255.255.0 192.168.x.2 1
route inside 10.0.x.100 255.255.255.255 192.168.x.2 1
route inside 192.x.x.0 255.255.255.0 192.168.x.3 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
console timeout 0
terminal width 80
Cryptochecksum:xxxxx
: end
In theory what you say is correct but in actuality it wont happen. Reason is that the Pix will not send it back out the same interface.
Traffic from 192.168.x.10 goes to Pix1 which has the route to 10.0.x.0 via 192.168.x.2 (Pix2 Outside) when the pix gets this it drops the packet because it violates the security design of the Pix.
Any "router" would do .. if you are looking cheap, Linux box, Linksys, *shudder* Windows.
erickflamenco
Level 3
Level 3
I guess the default gw for 192.168.x.10 is 192.168.x.1 and taking in account that the PIX is not a router, you should add a persistent static route to host .10 to look for network 10.0 through PIX-2's outside interface.If this is a windows based host, this should be something like
route - p add 10.0.x.0 mask 255.255.255.0 192.168.x.2
PIX-2 also, should permit outside-inside telnet xfic.
Erick
Thanks for your response.
I do have telnet traffic permitted on PIX-2 and I can telnet fine after adding a static route to any of the workstations that I'm working off of. That is how I have been operating up until now. But I would think I should be able to add a static route to the gateway of 192.168.x.2 which would lead to the 10.0.x.0 network and this shoudl be on PIX-1... right?
Also... would is the ideal router for small networks with minimal routing such as the one I have been describing. I am essentially using the PIX firewalls as routers on all three networks.
rmeder
Community Member
Ahh... makes perfect sense! I guess I will be adding to the route tables of the workstations for the time being.
Can you recommend a cisco or equivelant router to be used in this situation? There are about 15-25 nodes on each network. The communication accross them will continue to be very minimal.
Thanks again for your assistance!
Rick
