Telnet problems
c-hayward
Community Member
I'm trying to telnet to an address inside my firewall and receive the following error message
305005: No translation group found for tcp src htzlan:192.168.180.187/2117 dst management:192.168.182.33/23.
Can anyone explain what might be happening?
jmia
Level 11
Level 11
Hi Chris -
Have you got the following cmd on your firewall inside interface:
> telnet inside
also make sure that the inside ip addrs is a static ip instead of dynamic,
Hope this helps -
jmia
Level 11
Level 11
Chris -
Also forgot to ask, which version of IOS you running ?
Thanks -
