using object-group
mindorewala
Community Member
I would like to block all ports by default on outside interface on firewall.
Only selected ports should be open.
Pls. find the attached firewall config.
If i remove the below line from config (page 1: second last line)
access-list intf2_access_in permit ip any any
(page 2: 3rd line from top)
access-list outside_access_in permit ip any any
traffic doesn't flow.
What could be wrong and how can we resolve and apply object group for port blocking.
mehrdad
Level 7
Level 7
check this out :
access-list intf2_access_in permit tcp any any eq object-group allow
Mehrdad Arshad Rad
any effect on the NAT, if i apply this statement!!!!
Thanx a million
Mustafa Indorewala
I checked this command, but it doesn't accept.
Mustafa
use it without 'eq' operator, like below :
access-list intf2_access_in permit tcp any any object-group allow
