03-26-2020 09:02 AM
I am not a true licensing guru when it comes to stealthwatch. I know up to 250 exporters that will be close to 4,500 flows per second. But is there a true calculator out there where you can plug in the number of switches/exporters to determine the number of flows per second a customer needs for licensing?
03-26-2020 09:42 AM
Hi! In my experience, the best way to do that is by collecting data with UDP Director.
Regards!
03-26-2020 09:10 PM
If your customer doesn't purchase Stealthwatch yet, I recommend them to use an evaluation license(PoV) in the production network. Flow Collector can show true Flow rate in web UI. Of course, UDPD also shows Flow rate too.
Or if your customer is a certain volume customer then there is another option as EA(Enterprise Agreement). In EA, the customer doesn't need to care about Flow Rate.
04-23-2020 07:27 AM
Cisco provided this link when we were investigating the product eary on:
https://configurenetflow.info/
04-23-2020 07:51 AM
05-22-2026 06:20 AM
Stealthwatch Flow Rate Calculator helps in measuring and analyzing network traffic flow in a simple way. It is useful for understanding performance and detecting any unusual activity. Just like in other calculations, accuracy is very important here. You can also relate careful tracking habits with tools like chipotle nutrition calculator.
