thomas
This paper will focus on Identity Services Engine (ISE) ability to determine the endpoint state by doing a posture assessment. Before the release of ASA 9.2.1 VPN users requiring posture functionality required an Inline Posture Node (IPN) between the VPN infrastructure and the LAN protected network. With the release of ASA 9.2.1 we now have the ability to enforce policy the ASA and ISE has the ability to send a “policy push” after a posture assessment has taken place.
jsblendorio
Is there an update for the document for ISE 2.2?
thomas
Nothing has changed for ISE 2.2.
The fundamentals should remain the same.
Let us know if something no longer applies or is correct.
jsblendorio
On page 18, the should the NACagent 4.x continue to be used? This was replaced by ISE posture, right?
thomas
Right, AnyConnect with the Compliance module.
Please see How To Configure Posture with AnyConnect Compliance Module and ISE 2.0
jsblendorio
Thanks, this is helpful.
stayd
ISE3.2p7/ASA9.20.7.3/POSTURE:
if you get CoA-NAK from ASA.
Check if your tunnel-group has just authentication and accounting and not authorizing. If you have also autohrizing in required tunnel-group, then remove it, then CoA between ISE and ASA will work.
