Marty1
Visitor
Question
I am currently unable to specify "crypto keyring" command when configuring VPN connection on my cisco 2901 router.
The following licenses have been activated on my router :
Technology Technology-package Technology-package
Current Type Next reboot
ipbase     ipbasek9             Permanent          ipbasek9
security   securityk9           Evaluation            securityk9
uc           uck9                   Evaluation            uck9
data        None                  None                    None
Answer
Marty1
Visitor
When running **1(config)#crypto ?** I only get five options :
dynamic-map            Specify a dynamic crypto map template
ipsec                         Configure IPSEC policy
isakmp                      Configure ISAKMP policy
key                            Long term key opera
map                          Enter a crypto map
Why is there no **keyring** option ? ?
It's not only the the "crypto keyring"command that is missing ... First update the IOS to a recent version, it could be a bug. And you need to buy and activate the security-license if you want to use IPsec-VPNs.
159536
Frequent Visitor
Frequent Visitor
hi,
whether ESA-AMP-LIC= works with O365, can if offer security for sharepoint, one-drive??
