athukral
    Introduction:
    This document describes details on how NAT-T works.
    Background:
    ESP  encrypts all critical information, encapsulating the entire inner TCP/UDP datagram within an ESP header. ESP is an IP protocol in the same sense  that TCP and UDP are IP protocols (OSI Network Layer 3), but it does not  have any port  information like TCP/UDP (OSI Transport Layer 4).  This is a difference from  ISAKMP which uses UDP port 500 as its transport layer.
    PAT (Port Address Translation) is used to provide many hosts access to the internet through the same publically routable ip address.  PAT works by building a database that binds each local host's ip address to the publically routable ip address using a specific port number.  In this manner, any packet sourced from an inside host will have its IP header modified by the PAT devcie such that the source address and port number are changed from the RFC 1918 address/port to the publically routable ip address and a new unique port.  Referencing this binding database, any return traffic can be untranslated in the same manner.
    Q1: Why can't an ESP packet pass through a PAT device?
    It is precisely because ESP is a protocol without ports that prevents it from passing through PAT devices.  Because there is no port to change in the ESP packet, the binding database can't assign a unique port to the packet at the time it changes its RFC 1918 address to the publically routable address.  If the packet can't be assigned a unique port then the database binding won't complete and there is no way to tell which inside host sourced this packet.  As a result there is no way for the return traffic to be untranslated successfully.
    Q2: How does NAT-T work with ISAKMP/IPsec?
    NAT Traversal performs two tasks:
    1. Detects if both ends support NAT-T
    2. Detects NAT devices along the transmission path (NAT-Discovery)
    Step one occurs in ISAKMP Main Mode messages one and two.  If both devices support NAT-T, then NAT-Discovery is performed in ISKAMP Main Mode messages (packets) three and four.  THe NAT-D payload sent is a hash of the original IP address and port. Devices exchange two NAT-D packets, one with source IP and port, and another with destination IP and port. The receiving device recalculates the hash and compares it with the hash it received; if they don't match a NAT device exists.
    If a NAT device has been determined to exist, NAT-T will change the ISAKMP transport with ISAKMP Main Mode messages five and six, at which point all ISAKMP packets change from UDP port 500 to UDP port 4500.  NAT-T encapsulates the Quick Mode (IPsec Phase 2) exchange inside UDP 4500 as well.  After Quick Mode completes data that gets encrypted on the IPsec Security Association is encapsulated inside UDP port 4500 as well, thus providing a port to be used in the PAT device for translation.
    To visualize how this works and how the IP packet is encapsulated:
    1. Clear text packet will be encrypted/encapsulated inside an ESP packet
    2. ESP packet will be encapsulated inside a UDP/4500 packet.
    NAT-T  encapsulates ESP packets inside UDP and assigns both the Source and Destination ports as 4500.  After this encapsulation there is enough information for the PAT database binding to build successfully.  Now ESP packets can be translated through a PAT device.
    When a packet with source and destination port of 4500 is sent through a PAT device (from inside to outside), the PAT device will change the source port from 4500 to a random high port, while keeping the destination port of 4500. When a different NAT-T session passes through the PAT device, it will change the source port from 4500 to a different random high port, and so on. This way each local host has a unique database entry in the PAT devices mapping its RFC1918 ip address/port4500 to the public ip address/high-port.
    Q3: What is the difference between NAT-T and IPSec-over-UDP ?
    Although both these protocols work similiar, there are two main differences.
    • When NAT-T is enabled, it encapsulates the ESP packet with UDP only when it encounters a NAT device. Otherwise, no UDP encapsulation is done. But, IPSec Over UDP, always encapsulates the packet with UDP.
    • NAT-T always use the standard port, UDP-4500. It is not configurable. IPSec over UDP normally uses UDP-10000 but this could be any other port based on the configuration on the VPN server.
    Example:
    In above diagram, how does the device with PAT make unique identifiers in the PAT Table for both users if NAT-T sets the source and destination UDP ports 4500 ?
    If client A sends a packet, the packet will have the form:
    src: 192.168.1.5:4500  dst: 205.151.255.10:4500         - >       src: 205.151.254.10:600  dst: 205.151.255.10:4500
    If client B sends a packet, the packet will have the form:
    src: 192.168.1.6:4500  dst: 205.151.255.10:4500         - >       src: 205.151.254.10:601  dst: 205.151.255.10:4500
    the response from the server will have the form to each Client:
    src: 10.0.1.5:80  dst: 205.151.254.10:600                    - >       src: 205.151.255.10:4500  dst: 205.151.254.10:600
    src: 10.0.1.5:80  dst: 205.151.254.10:601                    - >       src: 205.151.255.10:4500  dst:
    205.151.254.10:601
    References-----
    Here is the RFC for the IPSec aware NAT (NAT-Traversal) for your reference:
    http://datatracker.ietf.org/doc/rfc3947/
    (It includes the full explaination of the negotiation for your reference)
    Document was create from the following discussion thread----
    https://supportforums.cisco.com/thread/2049410?tstart=0
    jeetintyagi
    rinatkazantsev1
    Amazing Thankyou, I will use it for my Puff Print Website
    @athukral wrote:
      Introduction:
      Background:
      PAT (Port **bleep** Translation) is used to provide many hosts access to the internet through the same publically routable ip **bleep**.  PAT works by building a database that binds each local host's ip **bleep** to the publically routable ip **bleep** using a specific port number.  In this manner, any packet sourced from an inside host will have its IP header modified by the PAT devcie such that the source **bleep** and port number are changed from the RFC 1918 **bleep**/port to the publically routable ip **bleep** and a new unique port.  Referencing this binding database, any return traffic can be untranslated in the same manner.
      It is precisely because ESP is a protocol without ports that prevents it from passing through PAT devices.  Because there is no port to change in the ESP packet, the binding database can't assign a unique port to the packet at the time it changes its RFC 1918 **bleep** to the publically routable **bleep**.  If the packet can't be assigned a unique port then the database binding won't complete and there is no way to tell which inside host sourced this packet.  As a result there is no way for the return traffic to be untranslated successfully.
      Step one occurs in ISAKMP Main Mode messages one and two.  If both devices support NAT-T, then NAT-Discovery is performed in ISKAMP Main Mode messages (packets) three and four.  THe NAT-D payload sent is a hash of the original IP **bleep** and port. Devices exchange two NAT-D packets, one with source IP and port, and another with destination IP and port. The receiving device recalculates the hash and compares it with the hash it received; if they don't match a NAT device exists.
      When a packet with source and destination port of 4500 is sent through a PAT device (from inside to outside), the PAT device will change the source port from 4500 to a random high port, while keeping the destination port of 4500. When a different NAT-T session passes through the PAT device, it will change the source port from 4500 to a different random high port, and so on. This way each local host has a unique database entry in the PAT devices mapping its RFC1918 ip **bleep**/port4500 to the public ip **bleep**/high-port.
      Example:
      205.151.254.10:601
      References-----
      (It includes the **ll explaination of the negotiation for your reference)
      Hello @athukral [CostcoESS](https://www-costcoess.com"CostcoESS")
      In the context of NAT Traversal (NAT-T) and its interaction with Port **bleep** Translation (PAT) devices, the unique identification of packets is crucial for successful communication. Here's how the device with PAT distinguishes between different users when NAT-T sets both the source and destination UDP ports to 4500:
      When **Client A** sends a packet, the PAT device modifies the packet's source port from 4500 to a unique high port number (e.g., 600), while the destination port remains 4500. The modified packet looks like this:
      - Original: `src: 192.168.1.5:4500 dst: 205.151.255.10:4500`
      - Translated: `src: 205.151.254.10:600 dst: 205.151.255.10:4500`
      Similarly, when **Client B** sends a packet, the PAT device assigns a different unique high port number (e.g., 601). The translated packet for Client B is:
      - Original: `src: 192.168.1.6:4500 dst: 205.151.255.10:4500`
      - Translated: `src: 205.151.254.10:601 dst: 205.151.255.10:4500`
      The PAT device maintains a binding table that maps each internal IP **bleep** and port (e.g., `192.168.1.5:4500`) to the public IP **bleep** and a unique high port number (e.g., `205.151.254.10:600`). This allows the PAT device to correctly identify and route return traffic to the appropriate internal host. For instance, the server's response to Client A would be translated back from the public IP and high port to the internal IP and port:
      - Original: `src: 10.0.1.5:80 dst: 205.151.254.10:600`
      - Translated: `src: 205.151.255.10:4500 dst: 192.168.1.5:4500`
      And for Client B:
      - Original: `src: 10.0.1.5:80 dst: 205.151.254.10:601`
      - Translated: `src: 205.151.255.10:4500 dst: 192.168.1.6:4500`
      This mechanism ensures that even though NAT-T sets the same source and destination ports for the encapsulated ESP packets, the PAT device can still create unique identifiers for each session in its PAT Table, allowing for successful bidirectional communication.
      Best Regards
      CostcoESS
