Blue_Bird
        Site-to-Site FlexVPN with IKEv2 Routing
Introduction
Lab Topology
Configuration
Verification
Introduction:
With FlexVPN, we have two options for routing:
  • Use a dynamic routing protocol like EIGRP, OSPF, or BGP.
  • Advertise routes within the IKEv2 Security Association (SA).
In this article, I am going show advertising routes within IKEv2 Security Association.
Lab Topology
R1 Configuration
Step-1: Interface Configuration
Router(config)#hostname R1
R1(config)#interface Loopback0
R1(config-if)# ip address 192.168.1.1 255.255.255.255
R1(config-if)#interface Ethernet0/0
R1(config-if)#ip address 1.1.1.1 255.255.255.0
R1(config-if)#no shutdown
R1(config-if)#exit
Step-2: Configure FlexVPN Settings
R1(config)#crypto ikev2 keyring KEYRING-R1
R1(config-ikev2-keyring)# peer R2
R1(config-ikev2-keyring-peer)#  address 1.1.1.2
R1(config-ikev2-keyring-peer)#  pre-shared-key local cisco@123
R1(config-ikev2-keyring-peer)#  pre-shared-key remote cisco@123
R1(config-ikev2-keyring-peer)#exit
R1(config)#aaa new-model
R1(config)#aaa authorization network FLEXVPN_LOCAL local
R1(config)#crypto ikev2 authorization policy AUTH-POLICY
R1(config-ikev2-author-policy)#route set access-list FLEXVPN_ROUTES
R1(config-ikev2-author-policy)#exit
R1(config)#ip access-list standard FLEXVPN_ROUTES
R1(config-std-nacl)#permit host 192.168.1.1
R1(config-std-nacl)#exit
R1(config)#crypto ikev2 profile IKEv2-PROFILE-R1
R1(config-ikev2-profile)# match identity remote fqdn R2.KL.LAB
R1(config-ikev2-profile)# identity local fqdn R1.KL.LAB
R1(config-ikev2-profile)# authentication remote pre-share
R1(config-ikev2-profile)# authentication local pre-share
R1(config-ikev2-profile)# keyring local KEYRING-R1
R1(config-ikev2-profile)#exit
Step-3: Configure IPSEC Settings
R1(config)#crypto IPsec transform-set TSET-R1 esp-aes 256 esp-sha-hmac
R1(cfg-crypto-trans)#mode tunnel
R1(cfg-crypto-trans)#exit
R1(config)#crypto ipsec profile IPSEC-PROFILE-R1
R1(ipsec-profile)# set transform-set TSET-R1
R1(ipsec-profile)# set ikev2-profile IKEv2-PROFILE-R1
R1(ipsec-profile)# exit
Step-4: Configure Tunnel Interface
R1(config)#interface Tunnel0
R1(config-if)# ip address 10.0.0.1 255.255.255.0
R1(config-if)# tunnel source Ethernet0/0
R1(config-if)# tunnel destination 1.1.1.2
R1(config-if)# tunnel protection ipsec profile IPSEC-PROFILE-R1
R1(config-if)#exit
R2 Configuration
R2(config)#interface Loopback0
R2(config-if)# ip address 192.168.2.2 255.255.255.255
R2(config-if)#interface Ethernet0/0
R2(config-if)#ip address 1.1.1.2 255.255.255.0
R2(config-if)#no shutdown
R2(config-if)#exit
R2(config)#crypto ikev2 keyring KEYRING-R2
R2(config-ikev2-keyring)# peer R1
R2(config-ikev2-keyring-peer)#  address 1.1.1.1
R2(config-ikev2-keyring-peer)#  pre-shared-key local cisco@123
R2(config-ikev2-keyring-peer)#  pre-shared-key remote cisco@123
R2(config-ikev2-keyring-peer)#exit
R2(config)#aaa new-model
R2(config)#aaa authorization network FLEXVPN_LOCAL local
R2(config)#crypto ikev2 authorization policy AUTH-POLICY
R2(config-ikev2-author-policy)#route set access-list FLEXVPN_ROUTES
R2(config-ikev2-author-policy)#exit
R2(config)#ip access-list standard FLEXVPN_ROUTES
R2(config-std-nacl)#permit host 192.168.2.2
R2(config-std-nacl)#exit
R2(config)#crypto ikev2 profile IKEv2-PROFILE-R2
R2(config-ikev2-profile)# match identity remote fqdn R1.KL.LAB
R2(config-ikev2-profile)# identity local fqdn R2.KL.LAB
R2(config-ikev2-profile)# authentication remote pre-share
R2(config-ikev2-profile)# authentication local pre-share
R2(config-ikev2-profile)# keyring local KEYRING-R2
R2(config-ikev2-profile)#exit
R2(config)#crypto IPsec transform-set TSET-R2 esp-aes 256 esp-sha-hmac
R2(cfg-crypto-trans)#mode tunnel
R2(cfg-crypto-trans)#exit
R2(config)#crypto ipsec profile IPSEC-PROFILE-R2
R2(ipsec-profile)# set transform-set TSET-R2
R2(ipsec-profile)# set ikev2-profile IKEv2-PROFILE-R2
R2(ipsec-profile)# exit
R2(config)#interface Tunnel0
R2(config-if)# ip address 10.0.0.2 255.255.255.0
R2(config-if)# tunnel source Ethernet0/0
R2(config-if)# tunnel destination 1.1.1.1
R2(config-if)# tunnel protection ipsec profile IPSEC-PROFILE-R2
R2(config-if)#exit
Verification:
Blue_Bird_1-1754568555661.pngBlue_Bird_2-1754568579754.pngBlue_Bird_3-1754568611043.pngBlue_Bird_4-1754568643747.png
............................................................................ Thank you very much..! ...............................................................................
Well explained with CLI configs !
