Role Based Access Control
rida-aaliya
Community Member
I have started dividing a single network to zones and have started provisioning Roles and access based on network tags. Is there any better way to create a segregation of networks or some best practices on RBAC?
Philip D'Ath
Meraki Community All-Star
Yes, that approach would work.
Also give some consideration to using SAML. You can then create named roles (which will use your tags) and then apply them to users dynamically.
https://documentation.meraki.com/MV/Advanced_Configuration/Restricting_Access_to_Cameras#Role-based_Camera_and_Sensor_Permissions_for_SAML.2FSSO
It is quite a bit of work, though, with that many roles.
Philip D'Ath
What kind of roles do you envisage having? And what sort of permissions would you like them to have?
rida-aaliya
Community Member
Thanks a lot for your response PhilipDath. we want to have 25 zones to distribute 100 plus cameras and I need to create 2 roles for each zone -Read and View access and I am trying to create micro segmentation of a big network and tag each zone and create two roles each per zone so I will have close to 50 plus roles with network tags. So wanting to know if there is a better way to solve this?
Rida
Philip D'Ath
