Adding a Server
imranraheel
Level 5
Level 5
I am new to MDS 9148 Switch & want to add a Server and want to share the EMC SAN, let me know if the specified commands looks good.
///Define Fcalias Name
fcalias name GICMSG02 vsan 101---------------------------------(Thats My Server)
member pwwn 50:01:43:80:12:0c:bd:5c
fcalias name BR_VNX_SPB0 vsan 101
member pwwn 50:06:01:68:3e:e0:0f:e6
fcalias name BR_VNX_SPA0 vsan 101
member pwwn 50:06:01:60:3e:e0:0f:e6
/////Create a Zone
zone name BR_VNX_SPB_GICMGT02 vsan 101
    member fcalias GICMSG02
    member fcalias BR_VNX_SPB0
zone name BR_VNX_SPA_GICMGT02 vsan 101
    member fcalias BR_VNX_SPA0
///Map Thats Zone to the VSAN
//zoneset name Production_Switch1 vsan 101
  //  member CX3221_A1_GICESX09_HBA1   Already in there & I will add the below commands
member BR_VNX_SPB_GICMGT02
member BR_VNX_SPA_GICMGT02
23 Replies 23
yes
@dynamoxxx
@dynamoxxx
edondurguti
Level 7
Level 7
I'm adding a server too and I've been to exposed to MDS/fibre/storage just for a week, did some reading and I do understand alot of it.
I have one MDS swtich connected to UCS and EMC, we added two new servers in UCS I need to do zoning for those two servers. I have the idea of all commands, just as the ones above, i'm doing device alias instead of fcalias.
From my reading I know you have to activate the zoneset.
So.
Create zone
Add memebers
go to already created zoneset
add the zone created above
Activate zoneset
Will it dusrupt anything? I am running basic mode but there are no other switches connected to it.. just the UCS and EMC so there are no E ports all of them are N ports.
Hello mate,
The zoning activate process is not disruptive to already active zone, unless if your modifications are not only incremental changes.
Richard
edondurguti
Level 7
Level 7
Thanks for you reply Richard, not sure what you mean by  'not only incremental changes'
here's an example
zone name VMSRV012_fc0_EMC01_SPA0 vsan 250
    member pwwn 21:00:00:24:ff:48:a5:a1
    member pwwn 50:06:01:60:3e:a0:5a:c5
zoneset name MDSNAP_250_FAB-A vsan 250
    member VMSRV003_fc0_EMC01_SPA0
    member VMSRV003_fc0_EMC01_SPB1
    member VMSRV004_fc0_EMC01_SPA0
    member VMSRV004_fc0_EMC01_SPB1
    member VMSRV005_fc0_EMC01_SPA0
    member VMSRV005_fc0_EMC01_SPB1
    member VMSRV006_fc0_EMC01_SPA0
this is current
I'm trying to add
to
and then activate.
this should not delete or disrupt anything?
Thanks for your reply
This is not disruptive change.
For example, would be disruptive if you try to change the entire zone for another.
Thanks Mate,
I'm in the learning process of datacenter technologies and fiber :] coming from ethernet/routing/switching.
if you noticed your sever needs to be zoned to at least one port on SPA and one port onSPB (each HBA), this is best practice for Clariion/VNX arrays.
@dynamoxxx
@dynamoxxx
Yes. The FC1 is added on vsan251. I have inherited the config.
Basically everything talks to everything. Do u have a best practice doc ? Id appretiate it
i don't think it's documented anywhere but it's common knowledge for folks managing Clariion/VNX arrays.
@dynamoxxx
@dynamoxxx
