Command help.
spwvol1978
Community Member
Is there a command to put all ports in the isolated vsan?
I am setting up 2 new 9509's
The thought is to initially put all ports in vsan 4094. Then as my Prod, Backup and SRDF vsans are created ports will be allocated to their assigned vsan
The customer has a lot of unused ports at this time so the unused ports would be left in vsan 4094
Is this common practice? Thoughts?
Regards.
5 Replies 5
colin.mcnamara
Level 5
Level 5
Sleep well, you are following the best practice.
Colin McNamara
CCIE #18233 - Storage Networking
Do you know the command though?
Regards.
G'day,
I usually make vsan 1 my isolated vsan as when someone adds a new line card all ports automatically get put into vsan 1 🙂
nitro_rs4
Community Member
Be real careful with this command. You enter something wrong and bang you take down your systmes.
Config -t
vsan database
vsan 4094 interface fc 1/1-48
end
copy run start
Of course, you have to enter the module and port numbers that match your setup.
Thanks nitro.
This will be done on the initial setup of the switch b4 anything is plugged in.
Regards.
