Error while upgrading Firmware
murtuza.topiwala
Community Member
Am upgrading my cisco MDS9513 firmware from 3.0.2(b) to 3.2.3(a)..I get following errors when i start the installation,have done installation successfully on other switches,but this switch in particular throws the error.
Appreciate your help..Thanks
Setting boot variables.
[# ] 0% -- FAIL. Return code -1.
Install has failed. Return code 0x4093000C (Setting boot variables failed).
Please identify the cause of the failure, and try 'install all' again.
Michael Brown
Most of the time this is caused by a syntax issue with the 'install all' command.
Please ensure that the kickstart and main SAN-OS image are on the active supervisor bootflash and then issue this command from the command line.
install all system bootflash:m9500-sf2ek9-mz.3.2.3a.bin kickstart
bootflash:m9500-sf2ek9-kickstart-mz.3.2.3a.bin
Follow the prompts and at some point you will need to enter Y to continue.
I have seen where the module number, or sup-local was used in the install command and it caused problems.
Hope this helps,
Mike
Michael Brown
Hope this helps,
Mike
Thanks Mike,the solution turned out to be almost the same what you suggested..I opened up a case with Cisco and here is what he suggested.
CSCsr12337
install all Return code 0x4093000C when //sup-local files used
Symptom:
the upgrade process will fail if the "install all" command
is given a module location as part of the image uri. eg:
install all kickstart bootflash://sup-local/image_filename
Workaround:
do not use module locations when specifying image uri's.
The command "install all..." may eventually also fail thereafter
with the same error code, even if not using the prefixes //sup-local/ etc.
This may happen if the boot variables on the standby already contain
these prefixes - this can be checked with "show boot" and to see
which is the standby use "show mod".
Here is the procedure how to recover from that scenario:
1. Remove the incorrect boot statements:
conf t
no boot kickstart
no boot system
if that is accepted, go directly to step 4.
Otherwise if the switch returns:
failed to clear bootvar kickstart ( or system )
then go to step 2:
2. In that case you first need to perform system switchover:
- make sure that "show system redundancy status" shows the system
is in "operational: HA" state
- issue "system switchover"
- wait until the system returns to HA state as above
3. Remove the incorrect boot statements:
conf t
no boot kickstart
no boot system
4. Restore the correct boot commands
conf t
boot kickstart bootflash:old_kickstart_filename system bootflash:old_system_filename
exit
5. issue "copy run start"
After the above - the upgrade should go through this time.
As per the defect CSCsr12337 mentioned above - this issue
should not happen even when using the absolute paths
- in the software versions that have the fix ( 4.1(2) and later ).
In earlier software versions, when hitting this issue
