Expect utility with MDS9509
mcastelliano63
How to disable the interruption (“more”) that command line MDS9509 when I use The Expect utility?
dynamoxxx
Level 5
Level 5
enter:
terminal length 0
@dynamoxxx
dynamoxxx
Level 5
Level 5
enter:
terminal length 0
@dynamoxxx
Hi Dynamoxxx,
Thanks about your answer, but there is another problem. Now, the output file stays trunced, don't show all information.
What is it the problem? Would you know?
Thansk
not sure what you mean, when i set that parameter and type "show zones" for example ...the whole output scroll in my ssh terminal.  Are you scripting something with perl ?
@dynamoxxx
No, I use scritp Expect directly.
