Exporting data collections to csv
angus.miller
Im trying to export data collections to csv via the documented "pm.bat export..." method. However there is no pm.xml file in the pm directory. There are data collections defined and I can export via the web tool.
How/when does the pm.xml file get created? Can I not access the rrd file content directly using rrdtool maybe?
MDS9000 firmware 3.2.3a
amritpatek
Level 6
Level 6
There are two methods of doing the Export, via FM and via CLI. Advised customer to ensure Performance Manager Server is actually running when doing export. Also, advised to try the export via FM to ensure that is working and then compare the export to the CLI method.
Use the Export from the command
Step 1:
Go to the installation directory on your workstation and then go to the bin directory.
Step 2:
On Windows, enter .\pm.bat export .
amritpatek
Level 6
Level 6
Step 1:
Step 2:
Thanks worked a treat! I have a few more questions if I may:
1) May I ask were this is documented? I checked the docs and they required a pm.xml file as a second argument... e.g pm.bat export C:\....pm.xml
2) What are the names of the csv files?
Thanks again for your help.
Cheers
