EXT3-fs warning: checktime reached, running e2fsck is recommended - kernel
Dinjamin1
We are seeing the following meassages:
2012 Jan 17 03:25:20 MDSBDC09 Jan 17 03:25:20 %KERN-4-SYSTEM_MSG: EXT3-fs warning: checktime reached, running e2fsck is recommended - kernel
2012 Jan 17 03:30:28 MDSBDC09 Jan 17 03:30:28 %KERN-4-SYSTEM_MSG: EXT3-fs warning: checktime reached, running e2fsck is recommended - kernel
I can't find any info on same.
Please advise. Any actions required?
thanks!
blueyonderguy
how long are they running?
bnamazhw
run "system health check bootflash" or reboot the switch to fix the issue. what is the output of "show system uptime"
Dinjamin1
We see that the switch did run the e2fsk successfully and fix those errors.
e2fsck 1.27 (8-Mar-2002)
/dev/hd-cfg0: recovering journal
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Free blocks count wrong (34334, counted=34279).
Fix? yes
Free inodes count wrong (9920, counted=9918).
Fix? yes
/dev/hd-cfg0: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hd-cfg0: 42/9960 files (0.0% non-contiguous), 5505/39784 blocks
/dev/hd-cfg1: recovering journal
Free blocks count wrong (33356, counted=33301).
Fix? yes
Free inodes count wrong (9680, counted=9678).
Fix? yes
/dev/hd-cfg1: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hd-cfg1: 42/9720 files (0.0% non-contiguous), 5475/38776 blocks
/dev/hd-pss: recovering journal
Free blocks count wrong (33756, counted=33512).
Fix? yes
Free inodes count wrong (9875, counted=9870).
Fix? yes
/dev/hd-pss: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hd-pss: 90/9960 files (5.6% non-contiguous), 6272/39784 blocks
/dev/hd-obfl: recovering journal
Free blocks count wrong (7246, counted=7232).
Fix? yes
Free inodes count wrong (2132, counted=2130).
Fix? yes
/dev/hd-obfl: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hd-obfl: 14/2144 files (7.1% non-contiguous), 1336/8568 blocks
/dev/hd-bootflash: recovering journal
Free blocks count wrong (189131, counted=161555).
Fix? yes
Free inodes count wrong (112210, counted=112208).
Fix? yes
We will monitor the switch for its frequency.
We have looked at the flash and I do not see any directory 100% full
thanks
