HBA card not visible
kuripr01.wa
TAC ID   : prakashkalluri
Model   : UCSC-C220-M4S
S. No     : FCH1932V3A0
Problem Details : HBA card not visible in storage switch end.Even we tried reseting the HBA physically.
Only 1 HBA is connected.
Let me know your advice to proceed.
dynamoxxx
Level 5
Level 5
what kind of troubleshooting have you done so far ?  If the WWN is not logged-in to the switch you need to validate your cabling, patch panel ..etc.  If WWN is logged-in to the switch but not logged-in to your array, then you need to validate your zoning.
@dynamoxxx
Walter Dey
Do you use CIMC ?
Do you see the adaptors in CIMC ? inserted in PCI slot x ?
Which type of I/O adaptor ?
Is the option rom enabled ?
see https://supportforums.cisco.com/discussion/12621021/fc-san-boot-c260-m2-server-and-vic-1225
