how do i connect a qlogic switch to a MDS?
antonio.quental
I am trying to connect a Qlogic switch to an upstream 9506. QLogic states that it supports a feature called transparent routing. I have done all the appropriate configuration, but the Qlogic does not see any remote devices from the Cisco switch. I have NPIV enabled on the 9500 and it sees the Qlogic as a host. Is there anything I need to do on the 9500 to push down it's members to the Qlogic switch?
dynamoxxx
Level 5
Level 5
On MDS do you see any devices connected to Qlogic in "sh flogi database" ?
@dynamoxxx
