how to clear the error counter on device manager
praneeth34
hi,
we have 2 9513s and 2 9509s in our environment recently I saw one of the port was disabling because of bit error threshold. temporarily I made the port to ignore the bit errors in the cli.
will this lead to any other issue ?
now when I clear the error counter in the cli it resets to 0 in cli but devicemanager still sums up the errors.
we are running OS 3.2.2c
any help is greatly appreciated.
ivillegas
Level 6
Level 6
You can first execute "show hardware internal packet-flow dropped". This will show which device has the drops. Then you can use "clear asic-cnt list-all-devices" which
will give the device ids for all devices on that board. Then you can issue "clear asic-cnt device-id " to clear the counter for only that device.
ivillegas
Level 6
Level 6
thanks for the reply. switch gives me eoor "invalid command" when I try to execute "clear asic-cnt list-all-devices" do we have to be at any particular code level for this. currently its running on 3.2.2c
My Bad... just discovered tht we have to attach to the module and run the command.. and it works .
thanks a lot.
