How to disable debug option - Bypass Loopback Diag
Zubair.Sayed_2
Hi Fellow Networkers....
I need to disable the following on a MDS 9222i SAN switch.
SAN1# sh debug
Ethernet Port Manager:
Bypass Loopback Diag  is on
I have tried various no debug commands but it doesnt seem to work.
Zubair
kenk
Hi Zubair,
What version of code are you running ?  (e.g. reply with the output of "show ver")
Please try issuing "undebug all" and then try "show debug" again.
Ken
Thanks Ken for replying.
I have issued undebug all several times with no joy. I have also issued other no debug commands with no joy.
Output of "sh ver" below:
Cisco Nexus Operating System (NX-OS) Software
TAC support:
http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
  BIOS:      version 1.0.19
  loader:    version N/A
  kickstart: version 5.0(4)
  system:    version 5.0(4)
  BIOS compile time:       02/01/10
  kickstart image file is: bootflash:///m9200-s2ek9-kickstart-mz.5.0.4.bin
  kickstart compile time:  7/26/2010 15:00:00 [09/07/2010 21:02:14]
  system image file is:    bootflash:///m9200-s2ek9-mz.5.0.4.bin
  system compile time:     7/26/2010 15:00:00 [09/07/2010 22:12:15]
Software
Hardware
  cisco MDS 9222i ("4x1GE IPS, 18x1/2/4Gbps FC/Sup2")
  Motorola, e500v2  with 1036300 kB of memory.
  Processor Board ID JAE1238V2TH
  Device name: SAN1
  bootflash:    1023120 kB
Kernel uptime is 129 day(s), 23 hour(s), 40 minute(s), 8 second(s)
Last reset at 146690 usecs after  Sun Dec 26 12:50:04 2010
  Reason: Reset due to upgrade
  System version: 4.2(7b)
  Service:
Zubair
Hi Zubair,
I was not able to reproduce your issue with a 9222i running 4.2 code.  I'd suggest opening a
TAC Service Request (it may be a new bug).
Ken
Hi Ken.
Thanks for your time and assistance.
I will raise the TAC SR.
Z
