Nexus 7009 dropping packets
abbas.ali
Level 3
Level 3
I have a customer running Nexus 7009 running NX-OS 6.0.(4) and having some serious iSCSI issues which is affecting SQL and some critical applications.  The basic problem is dropped iSCSI packets which seems to indicate a network problem.  We tried eliminating MPIO at the host (Windows 2003 and Win 2008), as well as upgrading Proliant/Broadcom NIC drivers and MS iSCSI initiators, yet the problem persists.
Port 3/17-20 are connected to HP 3PAR Array (4 Nodes), and Port 4/19 as a test server. I don't know if it is a bug with the current Nexus software 6.0.4 or issue with the port settings.
See below the brief output (version, show interface stats etc)
show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2012, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 3.22.0
  kickstart: version 6.0(4)
  system:    version 6.0(4)
  BIOS compile time:       02/20/10
  kickstart image file is: bootflash:///n7000-s1-kickstart.6.0.4.bin
  kickstart compile time:  12/25/2020 12:00:00 [06/22/2012 12:26:16]
  system image file is:    bootflash:///n7000-s1-dk9.6.0.4.bin
  system compile time:     6/6/2012 18:00:00 [06/22/2012 14:03:20]
Hardware
  cisco Nexus7000 C7009 (9 Slot) Chassis ("Supervisor module-1X")
  Intel(R) Xeon(R) CPU         with 8251592 kB of memory.
  Processor Board ID JAF1649ABCL
  Device name: IAD-MDF-CSW1
  bootflash:    2048256 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 291 day(s), 19 hour(s), 41 minute(s), 31 second(s)
Last reset
  Reason: Unknown
  System version: 6.0(4)
  Service:
plugin
  Core Plugin, Ethernet Plugin
CMP (Module 1) ok
CMP Software
  CMP BIOS version:        02.01.05
  CMP Image version:       6.0(1) [build 6.0(0.66)]
  CMP BIOS compile time:   8/ 4/2008 19:39:40
  CMP Image compile time:  6/6/2012 18:00:00
CMP (Module 2) ok
CMP Software
`show module`
Mod  Ports  Module-Type                         Model              Status
1    0      Supervisor module-1X                N7K-SUP1           active *
2    0      Supervisor module-1X                N7K-SUP1           ha-standby
3    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
4    48     10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L     ok
Mod  Sw              Hw
1    6.0(4)          3.0
2    6.0(4)          3.0
3    6.0(4)          1.2
4    6.0(4)          1.2
Mod  MAC-Address(es)                         Serial-Num
1    84-78-ac-55-f8-b0 to 84-78-ac-55-f8-b8  JAF1649ABCL
2    84-78-ac-55-f3-e0 to 84-78-ac-55-f3-e8  JAF1649AASC
3    ac-f2-c5-e6-5f-a0 to ac-f2-c5-e6-5f-e4  JAF1647BHDK
4    e0-2f-6d-02-af-ac to e0-2f-6d-02-af-e0  JAF1648AAFJ
Mod  Online Diag Status
1    Pass
2    Pass
3    Pass
4    Pass
Ethernet3/17 is up
  Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: acf2.c5e6.5fb0 (bia acf2.c5e6.5fb0)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 21week(s) 2day(s)
  30 seconds input rate 1240528 bits/sec, 1893 packets/sec
  30 seconds output rate 44657920 bits/sec, 3720 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 1.07 Mbps, 1.79 Kpps; output rate 44.11 Mbps, 3.62 Kpps
  RX
    6212152185 unicast packets  429281 multicast packets  1217 broadcast packets
    6215450735 input packets  8325559809873 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  2868052 input discard
    0 Rx pause
  TX
    4365896409 unicast packets  6994873 multicast packets  5685775 broadcast packets
    4378577057 output packets  3636859601639 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
  1 interface resets
Ethernet3/18 is up
  Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: acf2.c5e6.5fb1 (bia acf2.c5e6.5fb1)
  Encapsulation ARPA
  Port mode is access
  EtherType is 0x8100
  30 seconds input rate 88 bits/sec, 0 packets/sec
  30 seconds output rate 832 bits/sec, 0 packets/sec
    input rate 168 bps, 0 pps; output rate 616 bps, 0 pps
  RX
    816332607 unicast packets  429272 multicast packets  4688 broadcast packets
    816770935 input packets  1029653115941 bytes
    0 input with dribble  4368 input discard
    0 Rx pause
  TX
    559486852 unicast packets  6994692 multicast packets  5682191 broadcast packets
    572163735 output packets  488780855539 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
Ethernet3/19 is up
  Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: acf2.c5e6.5fb2 (bia acf2.c5e6.5fb2)
  Encapsulation ARPA
  Port mode is access
  EtherType is 0x8100
  30 seconds input rate 957736 bits/sec, 1838 packets/sec
  30 seconds output rate 44128776 bits/sec, 3643 packets/sec
    input rate 941.03 Kbps, 1.75 Kpps; output rate 43.49 Mbps, 3.53 Kpps
  RX
    656897825 unicast packets  429277 multicast packets  4017 broadcast packets
    657333669 input packets  807689030859 bytes
    0 input with dribble  2550 input discard
    0 Rx pause
  TX
    492336795 unicast packets  6994825 multicast packets  5682939 broadcast packets
    505014559 output packets  437551853812 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
Ethernet3/20 is up
  Dedicated Interface
  Hardware: 1000/10000 Ethernet, address: acf2.c5e6.5fb3 (bia acf2.c5e6.5fb3)
  Encapsulation ARPA
  Port mode is access
  EtherType is 0x8100
  30 seconds input rate 32 bits/sec, 0 packets/sec
    input rate 88 bps, 0 pps; output rate 552 bps, 0 pps
  RX
    691372990 unicast packets  429273 multicast packets  4555 broadcast packets
    691824812 input packets  850421645740 bytes
    0 input with dribble  17994 input discard
    0 Rx pause
  TX
    516293350 unicast packets  6994665 multicast packets  5682306 broadcast packets
    528970321 output packets  457198205525 bytes
    0 jumbo packets
    0 Tx pause
  1 interface resets
Ethernet4/19 is up
  Dedicated Interface
  Hardware: 10/100/1000 Ethernet, address: e02f.6d02.afbe (bia e02f.6d02.afbe)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 1000 Mb/s
  Auto-Negotiation is turned off
  Input flow-control is on, output flow-control is on
  Auto-mdix is turned on
  EtherType is 0x8100
  Last link flapped 15:39:53
  30 seconds input rate 72 bits/sec, 0 packets/sec
  30 seconds output rate 1016 bits/sec, 0 packets/sec
    input rate 264 bps, 0 pps; output rate 600 bps, 0 pps
  RX
    65076 unicast packets  0 multicast packets  377 broadcast packets
    65453 input packets  50864500 bytes
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    49177 unicast packets  33361 multicast packets  22469 broadcast packets
    105007 output packets  41816639 bytes
    0 jumbo packets
    0 Tx pause
  8 interface resets
Luc Paulin
Community Member
