port trunking on 9506
anton.mssm
hi, would there be any advantage to do a port trunk to gain performance increase in speed/io through put?
scenario is as follows, I have 2 9506's, two seperate fabrics.
one netapp filer that has 8 ports, 4 for tape and 4 for disk luns.
would it make sense to create a port trunk for the 2 x 2 ports for tape or disk ?
I guess I am thinking like a bonded network for performance like in cisco switches, but does this apply to fc as well?
thank you
dynamoxxx
Level 5
Level 5
in FC world you create port-channel for switch to switch communication, not between target and initiator.
@dynamoxxx
@dynamoxxx
