Scripting for Cisco MDS
SAK_Mohan
Community Member
Though I know writing Scripts for Cisco MDs switches (as I don't rely on FM/DM GUI), I am wondering how to include comments in a script for better readability. Would appreciate if anyone could point me to the direction where it is been documented or how to do it.
Mohan
vmoopeung
Level 11
Level 11
With regards to your questions:
1- No, you must create the script externally to the MDS as specified in the doc listed below.
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/1_3_1/sw_confg/cnfig.pdf
You can however create a cron job on a host and login to the MDS via SSH providing Passwordless access to run a script. Let me know if this is something you would like to pursue.
2- Yes, this is a feature in version 2.0(1b) which was released recently to Cisco.com, look under "Command Scheduler" in the following link.
http://www.cisco.com/univercd/cc/td/doc/product/sn5000/mds9000/2_0/ol624901.htm
dkmurray55
Frequent Visitor
Frequent Visitor
"... how to include comments in a script for better readability." This question was not answered. Aside from using "!", is there a REM or other comment that does not generate an error message during script execution? The documentation does not provide a solution.
thx...
