Add capacity white paper?
BjornDewulf
It would be nice to have a seperate capacity white paper posted for each product.
Janel Kratky
Hi Bjorn,
Thank you for your feedback. Is there a particular product you are looking for?
Janel
Hi Janel,
I like the white paper of the GGSN (SAMI) and the engineering rules of the ASR5k, they make it possible to make a decision on the HW to select or to dimension when already in the network. It would be easier to signal needed extensions; An example for me lately was the 2951 ASR G2, we want to run MPLS, BGP, OSPF on this one. We can see it's supported but not what the limitations are of the box in terms of throughput, OSPF neighbours, MPLS limitations, ...
Maybe I am asking a lot, but I am sure this would help a lot of people in make a choice.
Thanks a lot for your concerns !
Kind regards,
Bjorn
Hi Bjorn,
I'm working with the documentation team and hope to have an update for you shortly.
Best regards,
Janel
